BarXT sensor needs Vin above 3.65 V
I’m using a BarXT sensor (the 100 bar version) and find it does not work with a Vin of 3.3 V.
The regulator needs a voltage above its output voltage to work,
Hi @PeteJan, welcome to the forum :slight_smile:
Not sure where you got that graph from, but the actual part number (per the public BarXT schematic on our product page) is CJ6206B33M.
I found this datasheet for that, but it’s unfortunately not obvious to me what input range it supports for a given output voltage variant. I’ve asked internally whether we’ve validated the full input range and will get back to you when there’s a response.
In the meantime I would recommend you submit our product problem form, since a product you have bought from us is not performing according to our advertised specifications.
Hi Eliot,
Thanks for getting back to me, I put in a product issue report.
Thanks for the data sheet. The plot I included was from Torex Semiconductor, https://product.torexsemi.com/system/files/series/xc6206.pdf for a similar part, I assumed the JIANGSU CHANGJING ELECTRONICS TECHNOLOGY CO., LTD part is a copy.
Regards,
Pete
