Hi!
I would like to use this config with a Wemos D1 ESP-Wroom-02 board.
I’ve soldered the SDA/SCL connectors to the esp direcly from bar30. Separately the oled and the bar30 sensor works fine. I mean same breadboard wiring and different example codes.
When I would like to init the oled and the sensor from one code I cannot. If I initialize the oled first ( display.init(); // Initialise the display ) I’ve got the sensor error messages ( Are SDA/SCL connected correctly? )
When I initialize the sensor first the sensor works but there is no oled display.
I use the SSD1306Brzo.h library for the oled display.
Any suggession?
Thank you!
