Yes, that’s an equivalent scenario.
Note that some of the ‘inaccuracy’ here also comes from the fact that if some of the target is closer to the sonar than other parts, how far away is the target? The sonar makes an estimate based on where it gets a strong response that’s consistent over time, but there’s some interpretation there as to which distance is being measured, and whether that’s the distance that’s desired for a given use-case.
It’s not possible for the sonar to “ignore” acoustic physics, but depending on the reflections from the water surface and other nearby walls (and the pool base, etc) there may be several reflections measured (at different strengths) for each output pulse, and if they end up with similar intensities to the reflection from the ‘target’ wall then it makes sense that the confidence in the distance estimate would go down.
Absolutely.
The measured intensity of an acoustic reflection is a combination of
- the transmission strength
- the receiver gain, sensitivity (resolution), and measurement range
- higher gain means more resolution, but also increases the chance of clipping outside the detectable range
- how well the pulse frequency resonates with the receiver
- this is mostly relevant for systems with separate transmitters and receivers
- it can be affected by doppler shifts if the sonar and target are moving quickly relative to each other, although it’s unlikely to make a practical difference here
- the distance the wave travels
- the sound wave spreads out, and
- some of it is absorbed as it travels through the water
- the relative angle between the pulse wave direction and the surface it’s hitting
- straight on / normal / orthogonal reflections give stronger returns than reflections that are deflected away from the sonar receiver
- the relative angle between the returning wave direction and the sonar receiver
- straight on returns generally resonate more strongly than those coming in from the side/behind, which does hold for our Ping Sonar
- whether the receiver is ‘visible’ to the sound wave
- the pulse could be deflected away from the sonar
- the pulse could be blocked by an obstacle on the way back (unlikely, given the relative speeds, unless it’s something mounted to/with the sonar)
- the sonar could be moving quickly enough to miss its own reflection region (very unlikely, given the relative speeds)
- the density difference between the transmission material (in our case generally water of some sort) and the target material(s)
- large density differences make for strong reflections
- similar densities make for weak reflections
- in the extreme, no density difference is like travelling through the same material, and has no reflection
- if the density changes gradually over space (relative to the sonar pulse’s frequency wavelength) then the reflection will be less strong, and will be hardly to precisely measure
- consider how one would try to define the exact location of the material transition in some water that gets murkier and siltier until eventually it’s mud and then stone
- the thickness and shape of the target material(s)
- very thin materials won’t reflect as much of the wave, and may allow a fair amount to travel through
- some shapes (and material/density distributions) are well suited to capturing / absorbing / deflecting the wave, rather than reflecting it back at the sonar
