Surfboard powered by 2 T200
thanks Jacob.
i am using a 4s 50c 6600 mah battery.i am using the blue green and white wire that is with the t200 and have made it a bit longer whit some bullet connectors. and the smae wire. total is like 5ft. the wire from the battery to the esc is thicker then the wire on the esc. and about 6inch. out of the water the thrusters work fine. i looks like it shuts off under load. building the board with all the wires in the stringers took all of mine time and i did not do any tests.
