ROV Design 101: articles and tips on designing ROVs
With decades of combined ROV experience at Poseidon Robotics, we want to make it easier for hobbyist and engineers alike to design their own ROV and related components. We are very excited to see how Blue Robotics has facilitated the explosion in people making their own ROVs and with much better components than were previously available to most people. To that end, we are now publishing a weekly series of articles on LinkedIn and X about ROV design.
In the meantime, here are some short tips on ROV design:
ROV design 101 - Here are the 10 most important things to remember when designing an ROV frame:
  1. Center of Mass directly below Center of Buoyancy = Positive Static Stability.
  2. Center of Pressure near Center of Thruster = smooth flight.
  3. Vertical thrusters near corners = good dynamic stability.
  4. If you will grab something with an arm on the front, put some of the vertical thrusters as far forward as possible.
  5. Keep center of mass close enough to center of buoyancy and center of pressure to keep the vehicle maneuverable.
  6. Have enough space for all equipment it’s intended to fly with (and just a bit more).
  7. Add a little more buoyancy than is needed.
  8. Control “Scope Creep” or it’ll never fly well, even if it can hold a kitchen sink.
  9. Do not obstruct the thrusters, as this will significantly effect power and efficiency.
  10. Pay attention to Thrust to cross sectional area ratio in the X, Y, and Z axis. It’s all about the effective thrust to unit area of the vehicle. Calculate for Forward, Lateral, and Vertical movement separately.
Remember that EVERYTHING in engineering is a trade off. Every designer will need to fine-tune their design based on the desired payload, available parts, and a hundred other criteria.
Please check back on our social media feeds or visit or website to sign up for our newsletter.
Subscribe on LinkedIn LinkedIn Login, Sign in | LinkedIn
Our latest article on Optical Fiber vs Copper for tether communications is now out. Enjoy.
If you ever wanted to know how to get your electronics to handle higher pressure without a pressure vessel, have a read below. I will post some follow up articles in the future because it’s a long and topic. If you have any specific questions, please do not hesitate to reach out to me directly.
Here’s a topic that comes up frequently when talking about surface power in small ROVs: Power Management. Choosing a power supply for your ROV isn’t usually as simple as selecting a voltage and replacing the battery. If you want to some practical examples of how we select a power supply for T200 and T500 thrusters, please have a read below:
