Hi @PeterM, lots of interesting things here ![]()
Unfortunately I’m quite short on time at the moment, so will have to keep this reasonably brief, but happy to discuss further as relevant and as things progress.
It’s possible to manually set the current global position, in which case (if the DVL is reporting valid velocities) you should be able to run ArduSub autonomously to follow a mission (e.g. scanning along your polygon or whatnot).
If you’re triggering image capture using software on the onboard computer (e.g. using a BlueOS extension) then it should also be able to get the current position from the MAVLink stream and add it to the image metadata, which would save having to do data alignment stuff in post.
This is partially dependent on the vision system, and partially dependent on the environment and vehicle state. The vision system you’ll need to tune with hardware selection/design, but you can improve your chances of getting a good image by either stopping the ROV when taking an image (and potentially monitoring the accelerometer and velocity data to only capture when “still enough”) and/or taking multiple images and (automatically) choosing the sharpest one to keep at each location.
This thread may also have some relevant advice.
I doubt there’ll be much value in modifying ArduSub itself, but it will likely be worth at least monitoring the MAVLink stream for position and motion telemetry data, and potentially for notice of intended image capture points (if they’re specified in the mission).
Not for static image capture at the moment (so probably not), but potentially if you’re wanting a video stream that’s advertised over MAVLink.
I believe ArduPilot missions support events at waypoints, so for software triggering it should be possible to send a MAVLink message that your software (on the onboard computer or the control station computer) can monitor for and run the image capture process as appropriate, or for hardware triggering it could toggle one of the flight controller’s relay outputs.
Do you need the images as they’re taken, or only after the dive? That may influence what makes the most sense. I don’t see how MAVLink would be relevant for image transport, but (again) data from the MAVLink stream will likely be valuable for the geolocation side of things.
QGroundControl has existing Survey functionality, but not all of the functionality is available for underwater vehicles, and I don’t believe it supports sending and displaying the images as they’re taken.
If you actually need to change the functionality and/or interface then I suspect Cockpit will make the most sense for this (since it’s being designed to be much easier to modify than QGC), but that depends a bit on how soon you’re wanting your interface to be “done”. Feature-wise this seems relevant to Blue Boat so I suspect we’ll be happy to help with the development.
We’re planning an initial beta release of Cockpit towards the end of this quarter, at which point there’ll be some documentation available and we’ll more meaningfully be able to discuss available features and the customisation process.
