Question on Signal Sending with Time Intervals by Pymavlinks
Check the safety section of the documentation.
The autopilot employs a some failsafe mechanisms to keep you and your equipement safe, as well as to prevent your ROV from running away from you during experiments.
All system components that communicate via MAVLink are expected to send a HEARTBEAT message at a constant rate of at least 1 Hz. If the autopilot does not receive a heartbeat from your application after this interval, it will trigger a failsafe.
When the autopilot is being commanded to move via RC_CHANNELS_RAW or MANUAL_CONTROL messages, the messages must be sent at a constant rate like the HEARTBEAT message. Otherwise, the autopilot will execute a failsafe if it has not received an updated command after a timeout period.
