Hello all,
I’m fairly new to coding in Python and ran into an issue. I’m using this code: https://github.com/bluerobotics/ping-python/blob/master/examples/simplePingExample.py except instead of myPing.get_distance() I changed it to myPing.get_distance_simple(). The issue I am running into is that the sonar is giving the distance values every 4 seconds instead of instantaneously or every second. Do you know what I can do to resolve this issue?
Thank you for your help!
#!/usr/bin/env python
#simplePingExample.py
from brping import Ping1D
import time
import argparse
from builtins import input
##Parse Command line options
parser = argparse.ArgumentParser(description="Ping python library example.")
parser.add_argument('--device', action="store", required=True, type=str, help="Ping device port.")
parser.add_argument('--baudrate', action="store", type=int, default=115200, help="Ping device baudrate.")
args = parser.parse_args()
#Make a new Ping
myPing = Ping1D(args.device, args.baudrate)
if myPing.initialize() is False:
print("Failed to initialize Ping!")
exit(1)
print("------------------------------------")
print("Starting Ping..")
print("Press CTRL+C to exit")
input("Press Enter to continue...")
# Read and print distance measurements with confidence
while True:
data = myPing.get_distance_simple()
if data:
print("Distance: %s\tConfidence: %s%%" % (data["distance"], data["confidence"]))
else:
print("Failed to get distance data")
