My subsea power module
The below video link is showing the Delta ROV 750W Subsea Power Module.
Surface power system is plugged in 230VAC outlet and outputting 365VDC.
BlueROV2 Heavy configuration system is used on 200m tether.
System outputs 12VDC but 15VDC can also be supplied at client request.
This smaller video is showing the temperature of the subsea power module after a 20min stress test.
8mm power tether also available here: http://www.deltarov.com/new/product/8mm-power-tether/
Hi etienne,
Could you add this simple Surface Power Unit in your shop?
Hi Eloi,
I just added it now: http://www.deltarov.com/new/product/rov-surface-power-unit/
Cheers,
E.
Hello guys,
Here is the video of our 750W-15VDC Subsea power module:
Our suggestion is to use the 15Vdc output if using the fathom-x board.
If using our fiber optics modules, 12Vdc provides more thrust vs power efficiency.
Cheers,
E.
