Making a waterproof USB 3 cable
Hi guys,
I need to make a waterproof USB 3 cable with Blue Robotics penetrators on each side (optionally a subsea connector on one side).
I was thinking of using a 10 core PUR cable and solder on an usb C male PCB kit on the inside of side A, and a standard USB 3 on the inside of the enclosure on side B.
Side A:
Has anyone done this kind of custom cables before? Will it be problematic getting real USB 3 speeds?
Any input on cable choice?
Cable option:
Lapp Olflex Servo FD 798 CP 10 Core CY Control Cable 0.25 mm², 0.5 mm²
It would be nice to use the Fathom cable, but it is only 8 core.
I don’t know about long-term subsea use, and how it compares to the polyurethane jacket you’re considering, but L-Com sells high-flex USB-3.0 cables with a thermoplastic elastomer jacket:
http://www.l-com.com/usb-usb-30-high-flex-type-a-male-to-type-b-male-15m#
I bought some for this purpose (connecting an external camera through BR penetrators) and it seems pretty tough and flexible, but I haven’t pressure tested it to any substantial depth yet.
USB 3 has a bunch of shielded twisted pairs for tight electrical impedance control. If you’re going to need full USB 3 speed I’d expect you’ll run into problems if you don’t use real USB 3 cable, but I haven’t tried it. The shorter the better if it’s not properly constructed cable.
Maybe some usb 3.0 over ethernet adapters inside the device at each and and then just use the Fathom tether?
Hi Magnus
Did you ever find a good solution to this? We are looking for a solution for an external camera housing with USB 3.0 between the camera and electronics housing.
Did anyone find a solution?
Anyone find a workable solution?
Check out Blue Trail Engineering; Cobalt Connectors and Cables | Blue Trail Engineering
They can make USB connectors/cables. It’s a custom cable based on their 6pin
For this case i ended up with potting in a heavy duty USB 3 cable and resolder it. I did an extra shrink wrap on the outside. If BlueTrail makes USB 3 solutions now it is great. BlueTrail makes solid solutions, ive used loads of their products.
They do mention USB cables on their custom product page, although they don’t specify if it’s USB 2 or 3.
If @k-deboer is right that their USB offering is based on their 6 pin cable then likely it’s only USB 2 (although that may still be sufficient for many use-cases).
This is Damon from Blue Trail Engineering. @EliotBR is right, our cables and connectors will only work for USB2.
Love your work!
Would USB3 be possible in the future. It would open up a lot of options for UHD machine vision cameras etc. Unfortunately USB2 will not work for our use cases.
Thanks, Magnus! Unfortunately it may be a long time before we offer USB3-compatible cables and connectors. The electrical requirements are much more stringent than USB2.
I expect at some point there may be some kind of sealed USB-C connection for these use-cases, but in the meantime they’re likely best served by ethernet or fibre optic connections, or cables with permanent penetrations.
