Lifetime of T200 thrusters at full throttle?
What is the lifetime of T200 thrusters run at full throttle in 4°C saltwater at 20V? At 16V?
Hi @overblown_petri, welcome to the forum :slight_smile:
I don’t believe we have such specific lifetime analysis, but I’ve asked the relevant engineers and will get back when I’ve got a response :slight_smile:
I haven’t yet had a response from our main thrusters engineer, but I’ve been directed to our (quite new) T200 FAQs, which have a question about lifetime:
If there does turn out to be more information available I’ll make sure to pass it along :slight_smile:
The standard blue robotics esc’s won’t last at full throttle for more than a few minutes.
Our Basic ESC can handle up to 30 A constant current, provided there’s sufficient cooling. 30 A is above the maximum T200 current usage for any supply below 20 V.
That said, if the ESC is used in an acrylic enclosure and with no additional heat spreading or active cooling then it’s indeed possible it would overheat and fail when providing continuous high throttle for an extended period.
