I am working on an interface based on PyQt5 to control my ROV and am going to use 3 cameras on the vehicle. I am using GStreamer to stream the video outputs from the vehicle to the topside computer via ethernet and was successful with this step. To receive the video data I was planning to use the Video class provided here and I was going to show the streams simultaneously. The problem is that when I try to create a second instance Python is not able to create the appsink to receive the frame. To solve this problem I tried adding a button that would recreate the instance with a different port so that I could at least see the output but this failed too because even though I deleted the object yet again appsink could not be created. Out of curiosity while I was running my interface with a single Video object I ran another code which utilizes the Video class and the second I started that code the interface stopped playing the video. Is there a way to get around this problem? How can I display multiple streams using Blue’s Video class.
This is the error message given when I try to create another Video object.
Hi @Efe,
I’m unfortunately not able to test this at the moment. A few questions:
- Are you certain that all your video streams are actually available?
- Have you checked that they can be connected to with a direct gstreamer pipeline (instead of via Python)?
- Have you made sure that your Python code isn’t trying to bind two connections to the same UDP port?
The error message you’ve posted is telling you that the video_sink object is None rather than a meaningful gstreamer object, so presumably it failed to be created correctly, which (looking at the code) seems to be created by binding to the name appsink0. I see two options for that to fail:
- that element may not exist (because it failed to be created due to the stream not being accessible)
- gstreamer may handle names globally, in which case
appsink0may be taken by the first video stream, in which case the second one may need to bind toappsink1or similar- I’m curious whether that works - it may be a reasonably simple solution to the problem
Hi @EliotBR,
Thanks for your reply. I am sure that all the streams are avaliable and I have checked all of them via gstreamer command line tool. I am also sure that the ports given to the pipelines are both different and correct. As for your global naming theory, it looks like the most plausible reason, I will look into it and check if it’s the real reason. Thanks again for your reply.
PS: Also I found an alternative solution, you can use the same pipeline(the one in the Video class) with OpenCV’s VideoCapture class via CAP-_GSTREAMER but the problem is that you need to build OpenCV from source to enable GStreamer support.
Ok, fair enough
Indeed - I made a post about how to do that a while ago ![]()
