How to remove the "beeps" of my motor (with ESC)
Hi, we are working on the design of an underwater observation camera that should be silent, via a robotics project using a Raspberry pi.
We are using a brushless motor model F2838 which emits “beeps” when it does not receive any signal.
(In order to preserve our battery consumption, we are looking for a way to cut the signal to the motor when it should not be used)
We are therefore looking for a way to eliminate these regular “beeps”.
The problem comes from the ESC we are using. On the oscilloscope we could observe that it is the one that sends a signal to the motor.
So we need your help to answer the following questions:
Is there a way to set up the ESC so that it no longer beeps?
(We have not been able to connect our ESCs to BLHeli)
Is there a particular type of ESC that will not beep?
Can the beeper be removed directly from the engine?
Can we control the beeping of the motor from our Raspberry pi?
Details:
We have already tested the “Air20A” and “E series420lite” ESCs which emit the famous regular “beeps”.
The “Pro-Tronik BF 20A” ESC does not beep but does not run the motor.
Thank you kindly for your response…
The KOSMOS project
https://wikifactory.com/@konkarlab/kosmos30
Hi @KOSMOSproject,
To clarify, there is no “beeper” inside the motor, the motor itself is being used as a speaker by the ESC to emit tones. Both speakers and motors use modulated electric currents to move other parts of them, there isn’t much a difference mechanically.
The startup tones are intended as a critical diagnostic tool to check the connections between the motor and ESC. Each of the three initial tones indicated a connection for each phase, with the other two usually indicating “ready” and “armed” when initialized with a valid signal. It’s not a common use case to disable them altogether given the information they convey, so it may be tricky.
The beeping is something purely controlled by the ESC firmware for the ESCs I am aware of, it is not possible to control without directly modifying the ESC firmware. Though BlHeli_32 has some options for custom startup tones, I’m not sure if it’s possible to disable them entirely.
There are two options I suggest:
  1. Modifying the BlHeli source directly the remove the startup tones and compiling a custom firmware. There may be some developers on the project that could help you with this.
  2. Using something other than a commodity “hobby grade” ESC. More commercial/industrial focused ESCs may not have the same startup tones. Off the top of my head, I believe VESC based ESC may not have startup tones enabled by default. These may be a fair bit more expensive.
I hope this helps!
-Adam
The BLHeli32 configurator has a setting for Startup Beep volume. I assume it goes to zero, though I’ve never actually verified this. Of course, you’ll need to get a BLHeli32 ESC to make this work.
-W
