I was wondering how I can disable the brake on stop setting for the Basic ESC. I have been able to use a programming card with other ESCs in the past to change this setting. Is there an easy way to change this setting or will other programming cards with with this ESC?
Hi @gaddis13 ,
While some settings can be changed, unfortunately the brake is not one of them.
For reference, our ESCs run BLHeli_S firmware (which is not the same as BLHeli_32).
