I’m working on a robot and would like to charge the Blue Robotics Lithium-ion Battery (14.8V, 18Ah, BR-100842) using a solar panel while the vehicle is deployed.
I understand from the Lithium-ion Battery Guide and earlier forum threads (e.g. this one) that the pack has no built-in BMS and should be balance charged at 16.8V with a recommended current of 10A. Because of that, I don’t think a typical PWM solar charge controller designed for lead-acid batteries is suitable.
The setups I’m currently considering are:
Solar panel → MPPT controller → intermediate battery (lead-acid or LiFePO4) → DC-input lithium balance charger → BR battery
Solar panel → Li-ion compatible MPPT charger (set to 16.8V CC/CV) + an external 4S balancing BMS connected to the balance lead
Has anyone tried solar charging with a Blue Robotics battery, or with a similar 4S Li-ion pack without a BMS? I’d really appreciate hearing about:
What setup and components you used
Any problems with cell balancing or charge termination
Whether a 50W panel was practical for keeping the 18Ah pack charged during operation
Whether Blue Robotics has any recommendations for this kind of use case
Hi @y-fujii -
I’ve implemented several projects, from aquaculture monitoring buoys to weather stations that charge 4S lithium batteries from solar. I highly recommend the Victron MPTT charge controllers, which can be configured via serial/usb connection to charge at whatever custom voltage necessary - as long as your solar panel’s MPTT voltage is higher than your target pack maximum (16.8V in this case.)
That same serial connection is also very handy for monitoring battery voltage, solar panel voltage, yield, and load current. There is some discussion of all of this in this NodeRed guide. The serial signal is 3.3V TTL levels, so can be connected directly to a Navigator JST-GH port - easy to accomplish with a kit of parts like this.
This depends entirely on your load! Working backwards, a 50 watt panel is likely going to make 25-30 watts in full sun (derating is fairly typical.) If it gets sun for 9 hours a day, that would generate 9*25 =225 watt-hours. If your load is constant, and spread out over 24 hours, then 225/24 = 9.375 (watt-hours/hours)=watts. That all assumes perfect charging efficiency and is just a quick envelope calculation, but it suggests that running a 3-4 watt load all day, every day would not be an issue!
The other thing to consider is weather - 9 hours of sunlight may be a good or bad day of generation in your area and season. When storms move thru and your panel is generating half as much energy, you can get by if you have sufficient capacity. Having the capacity to run your load for at least 2-3 days with no solar input at all is a good start, from what I’ve found in sunny tropical parts of the world! So for a 4 watt load, 24*4*3 = 288 watt hours, which is a bit more than the 4s18AH pack capacity. Doubling up would give you a lot of peace of mind!
Thank you so much for such a detailed and helpful reply! Your real-world experience with buoys and weather stations is exactly what I was hoping to hear about, and the back-of-the-envelope energy calculation was really eye-opening. It made me realize that solar should be treated as a way to slowly top up the pack during standby or low-power operation, rather than something that can keep up with the thrusters.
The idea of reading the charge controller data through the Navigator is also great. Being able to log battery voltage, panel voltage and yield in BlueOS would be very valuable for my research.
If you don’t mind, I have a few follow-up questions:
Cell balancing: Since the Blue Robotics packs don’t have a BMS, how did you handle cell balancing in your long-term deployments? Did you add an external balancing board to the balance lead, periodically balance charge the packs with a hobby charger, or find that the cells stayed well matched without any extra measures?
Panel voltage: My current panel is 50W with a Voc of about 22V, so its MPP voltage is probably only around 18V. Do you think this is too close to 16.8V to fully charge the pack? What panel voltage did you use in your projects?
Other charge controllers: I already have a Renogy Rover 2 (20A) MPPT controller, which supports a user-defined battery profile and has an RS485 port. Have you (or anyone else) tried using a Renogy controller with a custom profile for a 4S Li-ion pack? I’m not yet sure whether its user-defined settings allow a 16.8V charge voltage, so I’d like to check before buying a Victron.
Thanks again for taking the time to share your experience!
18V>16.8, or 16.6 as advised in the guide, so assuming your cables from panel to battery are not long or very high resistance, you should be fine! I’ve typically needed to run two panels in series, or a large enough panel to have a MPP voltage greater than 16.8.
The Victron is quite affordable, for your size system the 75/10 is <$50. If you’re able to configure the Renogy to output the appropriate max voltage, that should work as well!
Thank you so much for the follow-up and the links! The cell balancer recommendation and the note about setting all voltages to 16.6V in the guide are exactly the pieces I was missing. It’s also reassuring to hear that the balancer you linked has been working well for you.
Based on your advice, here is the setup I’m planning:
50W panel (Voc approx. 22V, MPP approx. 18V) → MPPT charge controller with all charge voltages set to 16.6V → Blue Robotics 4S 18Ah pack
A separate cell balancer connected to the pack’s balance lead
Short, thick wiring between the panel, controller and battery to minimize voltage drop
I’ll first check whether my Renogy Rover 2 allows all charge voltages (bulk, float and equalize) to be set to 16.6V in its user-defined profile. If it doesn’t, I’ll go with the Victron 75/10 as you suggested.
