import smbus
import math
import timeit
bus=smbus.SMBus(1)
class Motor:
def init(self,add):
self.add=add
#bus=smbus.SMBus(1)
bus.write_byte(self.add,0)
bus.write_word_data(self.add,0x00,0)
bus.write_word_data(self.add,0x01,0)
self.bbuffer=[0 for h in range(9)]
self.read_reg=[0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0A]
self.rpm1=0
self.voltage_raw=0
self.temp_raw=0
self.current_raw=0
self.identifier=0
self.rpmTimer=0
def millis(self):
return (int(timeit.default_timer()*1000))
def setspeed(self,speed):
self.speed=speed
bus.write_word_data(self.add,0x00,self.speed>>8)
bus.write_word_data(self.add,0x01,self.speed)
def setzeros(self):
def readBuff(self):
for s in range(0,9):
self.bbuffer[s]=bus.read_word_data(self.add,self.read_reg[s])
def update(self):
self.bbuffer[8]= 0x00
self.readBuff()
self.rpm1 = (self.bbuffer[0] << 8) | self.bbuffer[1]
self.voltage_raw = (self.bbuffer[2] << 8) | self.bbuffer[3]
self.temp_raw = (self.bbuffer[4] << 8) | self.bbuffer[5]
self.current_raw = (self.bbuffer[6] << 8) | self.bbuffer[7]
self.identifier = self.bbuffer[8]
self.rpm1 = float(self.rpm1)/((self.millis()-self.rpmTimer)/1000.000000)*60/float(6)
self.rpmTimer=self.millis()
def isAlive(self):
return (self.identifier == 0xab)
def voltage(self):
#return float(voltage_raw)/65536.0000005.0000006.450000
return self.voltage_raw*0.0004921
def current(self):
#return (float(current_raw)-32767)/65535.0000005.00000014.706000
return (self.current_raw-32767)*0.001122
def temperature(self):
self.resistance = 3300/(65535/float(self.temp_raw)-1)
self.steinhart=0
self.steinhart = self.resistance / 10000
self.steinhart = math.log(self.steinhart)
self.steinhart /= 3900
self.steinhart += 1.0 / (25 + 273.15)
self.steinhart -= 273.15
return self.steinhart
def rpm(self):
return self.rpm1
i have add it in the previous post but there is an error
<h6>Upload Errors:</h6>
Blue.py: Sorry, this file type is not permitted for security reasons
