Cockpit first Beta release!
Hi Rafael - just installed the Beta2 version and tested it in water and seem to work as well as Beta1. For feedback I note a couple of issues below!
  1. Video latency (freezing) seemed worse than Beta 1 although I get this stream error message after messing around with the video settings so perhaps that is it. Will work through the solution provided above to see if that solves the freezing.
  2. Added a button to trigger the camera to the wireless xbox joystick (record?) but has no effect.
  3. Want to add a mini widgit to display tether turns but can’t find the relevant Mavlink variable. Is there a list of variables that can be added to the miniwidgits or joystick buttons (sorry if i missed this in the docs but have tried!).
  4. Instructions for installing the new version were a bit confusing. I couldn’t find any procedure to uninstall (completely or otherwise) but seemed to install just fine using the extension pages in BlueOS. Please advise if this was incorrect.
  5. Many Thanks for this awesome upgrade to the BlueROV2!!!
