Building the world’s second consumer deep sea drop cam
Nice work, @Paucam! This is a really awesome video and overview of your adventure! Thanks for sharing here.
This is sweet, @Paucam! It’s been super fun to watch your project take life and we can’t wait for future updates :sunglasses:
Very cool project! I’m still hoping to put together a drop cam of my own, so I’ll be keeping an eye out for the GitHub.
Thank you! We will let you know when it is posted!
Hi Ivan, yes, we conducted our tests with the drop cam tied to a line, and also have galvanic time releases as a backup plan!
Dear @rjehangir and all, after three years since my last post here (I was pursuing other projects), I am happy to announce that I published the assembly guide and software to build the dropcam (called blue_eye) on GitHub. With this, anyone can contribute to the global movement of citizen science and ocean exploration. And the burnwire took a lot of work but now works fine!
Hi @Paucam,
It’s great to see an update on this project - thanks for sharing, and great work on all your development and testing so far! :smiley:
Some comments, questions, and suggestions for potential future improvements:
  • With our new Locking Enclosures (which you mention in the assembly guide) and WetLink Penetrators (which don’t seem to be mentioned), it could indeed achieve depths up to 500m :smiley:
    • potted penetrators may not consistently maintain a seal all the way to 500m - it depends a fair amount on the potting conditions
    • note that it may be worth epoxy-coating (potting) the exposed end of the cable jacket (and/or use cable with a water-blocking filler) and the ends of the wires, to avoid the high pressure water pushing in past the insulation
      • using a water-blocked connector could also resolve this issue, although is more expensive to do
    • to get beyond 500m would require a thicker and/or smaller dome (perhaps the electronics could fit into a 3" enclosure?), as well as new lights (at some point we’ll be releasing a new iteration of our Lumens, which should be able to go deeper)
  • It’s really cool to have a reference for a tested burnwire setup! :smiley:
    • I noticed that the guide example mentions it should burn for ~1 minute (section 4.16), but the code seems to tell it to burn for ~10 minutes - are these both just examples that depend on the wire being used, or were they supposed to both be the same?
      • if an external pressure sensor or an accelerometer were integrated, it may be possible to “burn” until a consistent lifting starts occurring, with the timeout used as a backup to avoid excessively running down the battery if it doesn’t seem to be working properly
    • I’m not sure how much current the burnwire setup uses when switched on
      • if it’s significant, it may be worth providing a close or even direct connection to the battery terminals, to avoid burning out the breadboard traces
    • for additional robustness, it may be worth covering the anode in moldable sealant, as electrical tape alone could still fail to keep the water out and end up corroding things
  • The “blue_eye” name is apt and interesting, but may be a bit confusing because there’s an ROV company called Blueye, so it could incidentally seem like this project is affiliated with them
  • The photos and wiring layout diagrams in the assembly guide should be useful for replicating your setup :slight_smile:
    • it may also be worth creating an actual schematic, to better share the logical intent behind the circuit connections, and help people to understand which connections are being made and why
      • there are free softwares that can make electrical schematics - Kicad is one for electronics design, and there are also a variety of online options, including just general diagram creation software that includes electrical symbols
  • The usage guide refers to our Switch as an “electronic switch”, but I would personally consider it (and the reed switch) to be electrical switches (because they are not electronically actuated), while your relay would be an example of an electronic switch :slight_smile:
  • Given the two Lumen lights are sharing the same signal, it may be worth daisy-chaining them (or just getting a pre-connected set), to save a penetrator spot in the enclosure
Dear Eliot, thank you so much for your feedback, it is terrific and you touch on several details that are critical for the device and also details to improve/correct the assembly guide. Will work on all them.
@Paucam Awesome work! Thanks for sharing this and documenting it so clearly.
Hi @Paucam! We’d love to feature this on our social media - is there anything you’d like us to highlight? Thank you in advance!
-Taylor
Customer Success and Subsea Social
