Wetlink penetrator vs 2019 T200 thruster
Hello Bluerobotics
I have a 2019 BlueROV Heavy, and due to vacuum issues, I replaced the potted penetrators with Wetlink Penetrators.
Unfortunately, however, I am still having trouble achieving a vacuum.
Trouble shooting this isue I saw that the cable of the T200 thruster is marked “Bluerobotics CAB-A-3-18AWG,” and I found in the revision History that the T200 was updated from 18AWG to 16AWG in 2021.
The “Compatible WetLink Penetrator” table lists the M10-6.5mm-LC for the T200. Is it correct that this is not the right one for T200 units from before 2021?
Do you have the specifications for the Bluerobotics CAB-A-3-18AWG cable?
Is it correct that I need the WetLink M10-6.5mm-HC penetrator for these T200 thrusters?
Many thanks for your help
Lennaert
Hi @Lennaert -
Do you have a pair of calipers? Checking the diameter of your cable is the best way to determine what WetLink Penetrator should be used. Off hand, I think the outer diameter of the cables didn’t change in that revision, or enough that a different size would be required, but checking yourself is the best option!
There are other ways to have issues with vacuum tests - are you sure the penetrators are what are leaking?
You’re testing both housings at the same time, and no tether is connected?
A small leak rate through the jacket of the standard Fathom ROV tether is expected - long term tests should replace the tether connection with a blanking bolt or bulkhead connector tether connection.
When you say you’re having trouble achieving vacuum you didn’t specify what pressures you’re reaching, and how quickly they are returning to ambient?
Hi Tony
If I measure the 18awg cable is 6.0 - 6.1mm
So that would be the m10-6.5mm-HC?
With the pump, I achieve a vacuum of 15 kPa, but as soon as I stop pumping, the gauge reading visibly drops back.
I test one enclosure at a time.
All penetrators are new, the enclosure is also entirely new
Thanks for helping
Lennaert
Hi @Lennaert
You’re using the correct size WLP if that’s the diameter!
The issue is in testing one enclosure at a time. The battery cable go between the enclosures, and so when you pump one down to vacuum, air can move along the space between the wires, inside the cable jacket and through both WetLink penetrators. That is why testing both enclsoures at the same time is required! See the video here.
Hi @tony-white
Just to be sure, I now have used the m10-6.5mm-LC as listed in the Compatible table.
And looking at the diameter it should be the m10-6.5mm-HC.
your answer: that is the correct size WLP, refers to the M10-6.5mm-HC, correct?
Will do a double vacuum test.
Thanks en best regards
Lennaert
Hi @Lennaert -
You’re correct- my mistake. The HC may be better suited, but unless you’re reaching extreme depths (500m +) the difference isn’t likely to matter much. A vacuum test should pass with either - the root cause is likely your single enclosure tesitng procedure, assuming they are linked by the standard WetLink Penetrator sealed cables (although this would happen with oldschool potted penetrators as well!)
Hi @tony-white
I performed a double vacuum test.
I used 2 hand vacuum pumps and after 15 minutes the battery enclosure dropped from 15 in Hg to 12 in Hg. The electronics enclosure dropped from 15 to 12.5 in Hg in 15 minutes.
It’s getting better, but it’s not completely right yet.
One small question, somehow I lost 2 of the enclosure extensions. I saw that you have a new version, the mounting clips for the Electronics Enclosure cradle (BR-100658).
Is there a 3D model available of this new mounting clip? I can’t find it on the site.
Lennaert
Hi @Lennaert -
Do you have a tether connectd to the 4" electronics enclosure with a WetLink Penetrator? If so, the leak rate you observe seems normal, as air can flow within this tether, past the penetrator, and into the enclosure at a slow rate. If you want to confirm, temporarily replace this with a blank penetrator and you should not lose vacuum at all!
A 3D model of the new mounting clip is not available - I don’t think it would function well if printed, as it is quite thin! You can reach out to the support team via the help center to see about special ordering it.t
