Hi! there was a lot of work put into improving heading performance on the latest ArduSub release (4.5.0-beta3, which should be the new stable tomorrow).
I have a couple of recommendations:
Use the latest stable BlueOS
Use ArduSub 4.5.0
make sure you calibrate your Gyros in BlueOS and that all axis readings are under 10. Bonus points for calibrating after the rov warms up for a couple of minutes, as the gyro has thermal drift.
ArduSub 4.5.0 has two new parameters used as a “backup location” for vehicle with no GPS (ORIGIN_LAT, ORIGIN_LON), those are used to get an estimative of the local magnetic field in order to do a 3d magnetic fusion isntead of the regular 2D. I recommend setting those.
Make sure the compasses show “Fully calibrated” in the BlueOS compass page
Leave COMPASS_AUTODEC enabled
If this doesn’t help, then I agree with @ljlukis that you could disable Auto Declination and used it to correct the offset
