Tablet with a good battery autonomy
Hi all,
Do you have any recommendation/models of tablet to use with a BlueRov2 ?
Previously I was using a Windows Surface Go 10’’ with 8 Go RAM. It works well but the battery autonomy is quite low.
Any suggestions?
Regards,
Since you are using a tablet that runs on 5vdc, you could attach a powerpack to the back. Bit of a hack but it would work.
When you are using it at your surface control station you can just plug it into a usb charger plugged into a 12v vehicle socket, wired to a group 24-27-29 deep-cycle battery at your feet.
Don’t toss a perfectly good tablet just cause the battery sucks. Be creative, fix the issue…lol.
