Hello everyone,
I am using an STM32 to control a T500 thruster through PWM signals. Since the STM32 outputs 3.3 V logic levels, I am facing an issue where the thruster does not stop properly in forward or reverse mode and requires an opposite command to stop. I suspected a logic-level compatibility issue, so I added a logic-level shifter between the STM32 and the ESC to convert the 3.3 V signals to 5 V. However, the same issue persists. Has anyone experienced a similar problem, and could the issue be related to PWM signal timing, ESC calibration, neutral pulse width, or the type of logic-level shifter being used?
