I have come across many different posts about BlueROV surface navigation, from ones about not being able to enter guided and auto mode to the immediate dive response from the vehicle once these modes are armed. I have been working on adapting my BlueROV to be a surface-only vessel through a few modifications: 1) I first made it operate remotely by removing the tether. I use QGroundControl to control and communicate with it during flight, as well as make the movement plans. I should also note that my ROV is in the heavy configuration. 2) I made the vehicle positively buoyant and added styrofoam floaties to guarantee it will not submerge. This has been very useful for recovering the vehicle and maintaining a connection. 3) I added a GPS antenna with a mast tower so it can reach satellites. This was the first step I did just to get coordinates to appear on QGroundControl. 4) Getting a depth sensor was the final piece I needed to make the robot actually run on its own. Mine had been used for a different robot, and without it I could not get into guided or auto mode. Once it was installed alongside the GPS, I was able to fly. 5) Most recently, I added an external compass, as my EKF kept spiralling, resulting in the robot making endless circles when trying to navigate between waypoints.
I have been making changes to the parameters, trying to adjust and improve the line-following capabilities. With the recent adjustment of adding a compass outside the capsule, the path following seemed to improve, along with slowing down the waypoint speed and increasing the radius of the targets.
I decided to write this to hopefully help people who come across the surface navigation for BlueROV and to hopefully gain some assistance in improving my robot. I tested it yesterday, and while it appears that the EKF no longer enters free fall and makes the robot spin in endless loops, the accuracy is not the best. The conditions were windy, and I suspect that had an impact, but I also noticed an improvement when I activated all the thrusters. Up to that point, I had turned off the vertical thrusters to get around the immediate dive response. When I activated all of the thrusters, the vertical ones tried to dive, but since the robot was positively buoyant, they never stopped. While this may burn through the battery quicker, I think there was some improvement in the path following. Ultimately, I think my issues with inaccurate travel stem from GPS-related errors, as the QGroundControl robot had very sporadic movements compared to the actual robot. My current fix was to add another GPS device and see if the accuracy improved.
This ended up being a lot of rambling, but I wanted more help on some things: 1) if there were any clues on being able to have the software ignore the vertical aspect of movement to improve flight without having the vertical thrusters on. 2) if y’all think a second GPS would improve the flight, or that there may be another issue I missed. 3) I keep changing the waypoint behavior between trials, and no matter what is selected, be it 'Never Change Yaw ’ or 'Face Next Waypoint ', there is usually a few seconds of spinning from the robot even after a trial has been performed. If this is just the robot finding itself, no worries, I would just love more info on how those behaviors change the procedure. I currently have not had consecutive waypoint trials that have instilled confidence in the robot’s ability to follow a waypoint behavior parameter or a line. I am not looking for any miracles, I just need some more information on the details of the waypoint following. I hope this helps someone, and I greatly appreciate the forums, as they have helped me quite a bit.
Lastly, I am fully aware that the BlueBoat is the better version of what I am trying to do; I only have access to the BlueROV, so I’m making it work.
