I’m looking into integrating a Sub-Bottom Profiler (SBP) onto my Blue Robotics BlueBoat to investigate sediment layers and distinguish between soft sediment and solid seabed.
Has anyone successfully installed or operated a sub-bottom profiler on a BlueBoat?
Are there any specific SBP systems you would recommend for use with the BlueBoat, particularly regarding size, weight, power requirements, and integration?
Any experiences, recommendations, or suggestions would be greatly appreciated!
Hi @Dave-B -
While not impossible, that’s going to be a big challenge. Sub-bottom profilers are typically quite large, heavy, and most importantly they can consume a lot of power. I’ve looked at this unit in the past and it’s the only one that I think may be possible to integrate on the Blue Boat that I’ve come across thus far. You’d probably want the version with automatic stabilization via motion sensor considering how small the platform is.
Somewhat annoyingly it requires topside hardware that would need to be integrated into the hull or an external case, potentially a Windows computer which really kills efficiency. Pricing is also steep, when I last checked 52k EUR for the non-stabilized version and 70k EUR for the stabilized version!
Best of luck, and if you find an alternative, please share it!
It’s not marketed as a sub-bottom profiler, but it uses the same technology to generate a low frequency beam penetrate the bottom. It is typically used for bottom classification of the type you describe.
As Tony said, they are usually huge, both because they need lots of power AND the low frequencies required to penetrate the sediment physically demand large and heavy transducers.
There is another type called a parametric sonar which uses sum and difference frequencies at 230dB (re1uPa) and the non-linear mixing in the water column form a low frequency pencil beam. This gives you an array that is only a few metres across and only weighs a tonne. It’s really cool technology though!
Sub-bottom profiling is really hard, which is why the airguns are still often used as a sound source.
You’re stuck between two competing requirements. You want low frequencies for penetration and high frequencies for resolution (and a reasonable sized transducer). It’s still going to chew through power.
See if you can find something around 10kHz. That thing that Larry suggested does look suitable.
