# Single thruster control
**URL:** <https://discuss.bluerobotics.com/t/single-thruster-control/2970>\
**Category:** QGroundControl\
**Created:** [July 12, 2018, 6:29am UTC](https://discuss.bluerobotics.com/t/single-thruster-control/2970 "2018-07-12T06:29:08Z")\
**Showing post:** 2
**Author:** ![patrickelectric](https://sea1.discourse-cdn.com/flex019/user_avatar/discuss.bluerobotics.com/patrickelectric/32/2162_2.png) [@patrickelectric](https://discuss.bluerobotics.com/u/patrickelectric)\
**Post date:** [July 12, 2018, 2:52pm UTC](https://discuss.bluerobotics.com/t/single-thruster-control/2970/2 "2018-07-12T14:52:42Z")
> [@Sending MAVProxy messages from a python program?](https://discuss.bluerobotics.com/t/sending-mavproxy-messages-from-a-python-program/1515/12):
> You can not put a setpoint on motor channels. Only non-motor channels are allowed with this command. It’s not supported. Use [SET\_MODE](http://mavlink.org/messages/common#SET_MODE). An enumeration is a list of possible options, states, related things. The [mavlink message spec](http://mavlink.org/messages/common) will tell you when the items from a particular enumeration are to be used as a parameter to the command.
_[View the full topic](https://discuss.bluerobotics.com/t/single-thruster-control/2970)._
