Sending ROV depth data to USBL
We are starting to use our USBL tracking system (a BATS from EdgeTech) for the BlueROV, and need to feed the real-time ROV depth data to the tracking software (Trackman). For depth data input, we can point Trackman to an IP address and port, and can specify TCP, UDP, or UDP broadcast. We have not previously accessed real-time data from blueos, only retrieved it after the dive from the logs. One potential wrinkle is that we have different laptops running the ROV and the tracking system, but both have ethernet. Could anyone give pointers for establishing a live depth data link? Thanks, Scott
Hi @ScottM -
This is definitely possible, but you’ve not specified a format, just the protocol of TCP/UDP. You can easily target a Mavlink stream of telemetry via broadcast or at a specific device IP, which would include depth, via the MavLink Endpoints menu. If you require another protocol, it may require custom software development - easy to spin up a BlueOS extension to accomplish this! The Trackman software documentation may include information on the expected format.
Ideally we’d send a NMEA sentence (DBT, DBS, or DPT), with or without checksum.
That leads us to this forum post: NMEA Output streams from ArduPilot , which indicates depth can be broadcast from the autopilot. Any input on whether that vs. a BlueOS extension is preferable? If the latter, can you point us to an example/workflow we can follow for building an extension?
