Hello dear forumers,
Today i was working on implementing the ALT_HOLD mode according to the pymavlink documentations. While i was reading and coding at the same time i got some questions in my mind.
When we are calling this function, we ignore some axes.
master.mav.set_position_target_global_int_send(
int(1e3 * (time.time() - boot_time)), # ms since boot
master.target_system, master.target_component,
coordinate_frame=mavutil.mavlink.MAV_FRAME_GLOBAL_INT,
type_mask=( # ignore everything except z position
mavutil.mavlink.POSITION_TARGET_TYPEMASK_X_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_Y_IGNORE |
# DON'T mavutil.mavlink.POSITION_TARGET_TYPEMASK_Z_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_VX_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_VY_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_VZ_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_AX_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_AY_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_AZ_IGNORE |
# DON'T mavutil.mavlink.POSITION_TARGET_TYPEMASK_FORCE_SET |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_YAW_IGNORE |
mavutil.mavlink.POSITION_TARGET_TYPEMASK_YAW_RATE_IGNORE
), lat_int=0, lon_int=0, alt=depth, # (x, y WGS84 frame pos - not used), z [m]
vx=0, vy=0, vz=0, # velocities in NED frame [m/s] (not used)
afx=0, afy=0, afz=0, yaw=0, yaw_rate=0
# accelerations in NED frame [N], yaw, yaw_rate
# (all not supported yet, ignored in GCS Mavlink)
after using this function in my code, do i need to re-enable these ignored axes? And if i need to, what is the way of doing this?
At the end of the documentated code, it says:
# clean up (disarm) at the end
master.arducopter_disarm()
master.motors_disarmed_wait()
do i need to disarm the vehicle, every time i use depth hold actions to re-enable that ignored axes? Or are there a way that is not requires me to stop the motors?
Thanks for the time you reading this, any help will be appreciated.
