# RC Override Control (65535) Not Working
**URL:** <https://discuss.bluerobotics.com/t/rc-override-control-65535-not-working/11775>\
**Category:** ArduSub\
**Tags:** pymavlink\
**Created:** [March 18, 2022, 8:47pm UTC](https://discuss.bluerobotics.com/t/rc-override-control-65535-not-working/11775 "2022-03-18T20:47:13Z")\
**Showing post:** 2
**Post date:** [March 21, 2022, 5:12am UTC](https://discuss.bluerobotics.com/t/rc-override-control-65535-not-working/11775/2 "2022-03-21T05:12:37Z")
Hi @Marios, welcome to the forum 🙂
> [@Marios](#):
> the override value (65535) does NOT work.
What do you mean by this? 65535 is the “ignore” value, which means [that channel doesn’t get updated](https://github.com/ArduPilot/ardupilot/blob/Sub-4.0/libraries/GCS_MAVLink/GCS_Common.cpp#L2935). Channels set to 65535 in an rc\_channels\_override message will maintain whatever value was already stored, which can potentially cause issues with other controls.
This quote (and the post it’s from) are relevant:
> [@When Python runs the "send RC" script, the result is incorrect](https://discuss.bluerobotics.com/t/when-python-runs-the-send-rc-script-the-result-is-incorrect/10803/4):
> the motion should be explicitly set to stopped before arming, otherwise arming can sometimes resume the last thruster state from the last time the vehicle was armed.
> If you’re interested I’ve made an example program [here](https://gist.github.com/ES-Alexander/ee1dd479dd728b7cef1bf936f9114e71), which sends regular heartbeats and handles arming/disarming and setting the flight mode.
I would also recommend you look into the [failsafes and timeouts](https://discuss.bluerobotics.com/t/t200-python-manual-control-error/11479/2) 🙂
> [@Marios](#):
> If i use Beta or Developement versions the override value (65535) works, BUT the pressure sensor is not recognized ( I use the [Bar30 High-Resolution 300m Depth /Pressure Sensor](https://bluerobotics.com/store/sensors-sonars-cameras/sensors/bar30-sensor-r1/)) so I cannot use “depth hold” mode, only stabilize.
In case you want to try running beta/devel anyway,
> [@WaterLinked DVL A50 integration not working](https://discuss.bluerobotics.com/t/waterlinked-dvl-a50-integration-not-working/11501/5):
> ArduSub beta recently had a couple of updates that apparently messed up a default parameter for the depth sensor. The issue should be fixed if you
> > [@Ongoing DVL-A50 issues](https://discuss.bluerobotics.com/t/ongoing-dvl-a50-issues/11419/10):
> > try setting `BARO_PROBE_EXT` to 768 and then reboot.
_[View the full topic](https://discuss.bluerobotics.com/t/rc-override-control-65535-not-working/11775)._
