# Raspberry Pi to Pixhawk 6X USB question
**URL:** <https://discuss.bluerobotics.com/t/raspberry-pi-to-pixhawk-6x-usb-question/13272>\
**Category:** Companion (Retired)\
**Created:** [November 27, 2022, 10:34pm UTC](https://discuss.bluerobotics.com/t/raspberry-pi-to-pixhawk-6x-usb-question/13272 "2022-11-27T22:34:22Z")\
**Showing post:** 20
**Post date:** [December 21, 2022, 6:04am UTC](https://discuss.bluerobotics.com/t/raspberry-pi-to-pixhawk-6x-usb-question/13272/20 "2022-12-21T06:04:07Z")
> [@rdehart](#):
> So I got telemetry for the newest version working again
Good to hear 🙂
> [@rdehart](#):
> … I attempted to upgrade mavproxy. It had trouble updating numpy because the lastest mavproxy wants 1.24 but the highest supported for python 2.7 is 1.16.
If I’m remembering correctly, the latest Companion Software images should have Python 2.7 and 3.4 available by default. If you’re wanting to install a more recent Python version there are some instructions [here](https://discuss.bluerobotics.com/t/updating-python-in-companion/10398/2). That said, adapting existing services/programs to successfully use a different Python version may not be trivial, especially if they were written without Python 3 compatibility in mind.
> [@rdehart](#):
> I noticed that it says here that the companion image can support a newer Raspberry Pi (v3B). Is that true?
> [https://www.ardusub.com/resources/downloads.html#companion-computer-images](https://www.ardusub.com/resources/downloads.html#companion-computer-images)
The Companion Software supports Raspberry Pi 3B hardware, yes - I wasn’t even aware there had been earlier hardware versions supported previously.
If it’s relevant, BlueOS is supported on Raspberry Pi 3B, 3B+, and 4B, and the base operating system for the images we build is Raspberry Pi OS Bullseye, which comes with Python 3.9 by default. The BlueOS-core docker image (which most of the services run in) also currently uses Python 3.9, although that may be upgraded soon.
_[View the full topic](https://discuss.bluerobotics.com/t/raspberry-pi-to-pixhawk-6x-usb-question/13272)._
