QGC Random crashes changing tabs
I find clicking through the tabs crashes qgc quite often now. I have also encountered same crash when changing params and saving param files.
Here are the errors that show up
(QGroundControl.exe:5768): GLib-ERROR **:gmem.c:103: failed to allocate 3110491 bytes
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files
(x86)\qgroundcontrol\QGroundControl.exe
not sure whats going on but its starting to be annoying
Thanks @kaosrulz, I’m looking into it. If you can, it would help if you would gather some additional information like:
  • QGC version
  • Operating system version
  • Computer model
It would be really good if you could find a list of steps to take that reliably reproduce the issue, but that may not be possible in this case.
You can follow progress on the issue here.
-Jacob
Thanks Jacob,
Qgc version -head 2017-06-15-0400
Windows 8.1 version 6.3.9600 build 9600
Toshiba Satellite P50t-B
i7 - 4700HQ
16 gig ram
AMD Radeon R9 M265x
2 gig DDR5
I have tried getting consistency of error but it is random. I can force it to crash if I click the tabs 2 quickly but then other times it will error out of the blue with no interactions.
Hope this helps yr debug
