I want to have a pulley guide for tether away from boat on an outrigger. This would make it easier for the Captain to see which way the tether is tending. That’s the basic problem is the ability for the captain to see where the tether is.
My thought is its diameter has to at least match the small diameter on the spool.
I have used two types of pulleys for that purpose. You don’t have to worry about the bend radius of the cable. The main thing to consider is you need a way to lay the tether through the pully in the middle of the tether.
For fresh water, a simple rock climbing pully like this will work. You rotate the side plate, lay the tether over the pulley, then rotate the side plate up and clip them together with a carbiner.
For salt water, this snatch block is the gold standard. A little catch allows the pulley to fall half open so you can lay the tether in, and then snap the pulley shut. I had one of these hanging on the outside of my survey boat for years and it never froze up or failed to easily open.
I recommend to follow BR technical guide; minimum bend diameter 75mm
I use plastic wheel rim with a diameter of 250mm to spare the tether, and minimize the drag.
Mounted to a upside down Y type of hanger.
All of that hanging in cranes.
