If I have a housing with a BR PRV installed and I need it to vent at a lower pressure than the design pressure of the PRV - i.e. 0.8+/-0.2 Bar changed to 0.3 Bar, is modification going to cause a leak?
The idea would be to change the spring for a geometrically similar coil but lighter wire.
The question is what is the minimum required initial loading of the o-ring that seals the plunger.
Has anyone tried this?
