Pre-dive hazard scanning on a BlueROV2-class vehicle - what would make you trust the output?
Hey everyone. I’m scoping out a problem in commercial diving and wanted to sanity check it with people who actually run ROVs.
The idea: ROV flies the site before any diver enters, and a DGX Spark (NVIDIA GB10, 128GB unified memory) in a box on the vessel turns the sweep into a timestamped hazard packet. Entanglement, debris, structural stuff, visibility as a turbidity number. Local inference, no cloud.
The memory matters because most inspection ROVs carry an 8GB Jetson Orin Nano, and you end up throwing away most of your sensor data just to avoid OOM crashes. With 128GB unified you can hold the whole survey at once.
From talking to divers, zero-vis is just the normal operating condition in the Gulf. Basically braille diving, working by feel. So I’m leaning sonar-first (BlueView/Oculus class) with the camera as backup.
For those running imaging sonar on inspection ROVs, what’s the failure mode you hit most? And what would a packet like that need to show before you’d hand it to a supervisor? Trying to scope the problem right before building anything.
Hi @francolinx -
Welcome to the forums!
Your post has a distinctive “AI” flavor to it, but that doesn’t mean it is not an interesting question!
It’s definitely possible to use an ROV to survey a site - real-time processing of stereo images is getting quite good - see this post.
Generally, an ROV is good for a small area, high detail survey using cameras. Covering large areas is much more efficient with sonars, like the Omniscan 3D, which can identify hazards like ropes in the water column. BlueView’s Oculus is comparable to the Sonoptix Echo - both are intended not to make maps, but have great situational awareness despite turbid water…
In my experiences cleaning up debris on scuba, sending the ROV down first to survey the site and let all the folks going to dive see the area, discussing the plan based on what is observed is invaluable, and requires no fancy model making or report generation.
