Power Surge Base Station connected to laptop
I have a problem when connecting the Blueboat Base Station to my laptop.
I use the USB cable for an ethernet connection with the laptop, as the wifi connection with the base station to the laptop resulted in severe latency issues.
This week the base station stopped working while wanting to do another survey on the same day with my blueboat.
I got a message that there is a power surge on the USB port and that an ‘unknown device’ requires more power than the port can supply.
The connector got hot, that you almost burn your fingers.
I tested the power output, at that moment there was a 8W power demand, but I suspect it was higher prior. It was difficult to get a reading as the USB C connection on the Base Station is really sensitive and prone to disconnects if the cable moves even the slightest.
All in all not happy with how the telemetry with the blueboat is established. It would’ve been better if there were 2 separate ports; USB for charging and RJ45 for connecting to a laptop.
Hi @mrturner
Welcome to the forums!
Sorry for the issue. It sounds like the USB port on the Base Station has been damaged, potentially by salty water?
You can reach out via the help center, report a problem with a product, including your order number to discuss further. Replacing the port is possible, and you may be using an older revision of the box. The system can charge at more than 5 watts, so I don’t see an issue aside from the connection not being recognized…
