Power management and sensors integration
For one of our research applications, we lately had to develop the following:
Power distribution board : 8 channels with customisable Voltage, current limit level, output on/off switch, voltage/current measurement.
General purpose sensor acquisition capacity: CAN bus, various I2C, Uart, RS-485, analog inputs
Custom low cost CTD probe, interfaced with that board.
ROS2 integration.
We are currently evaluating if it would be worth updating that design and integrate it with BlueOS, as power management seems to be a recurring topic on the BlueROV platform. In that context, I wanted to ask what would be the most of use:
  • Max voltage level: we currently have 12V. Would 24V possibility be of use?
  • How many channels typically?
  • Navigator flight controller already has lot of PWM outputs, but would it make sense to add some here?
  • On the sensing part, are RS-485, 4-20 mA analog inputs desirable?
- We could later consider integration of Atlas probes
