Hello all,
I am having trouble setting up the Ping360 widget in the cockpit app.
I have a Ping360 with the latest firmware connected to a Raspberry PI via the USB interface. Using Pingviewer app on Windows topside computer, I am able to detect the ping360 and display data on my topside computer. Pingviewer shows the 192.168.2.2:9092 as the connection address.
In BlueOS via the web interface blueos.local, I can open “Ping Sonar Devices” and the Ping360 is shown at Bridge UDP 9092 with FW 3.3.0.
If I open the Pingviewer extension in BlueOS, I am able to view the sonar data stream. The Device Management menu of this app shows the Ping360 connection at 127.0.0.1 Port 9092.
Now if I open up Cockpit and go to “Edit Interface” i can see the Ping360 widget at the bottom of the screen. Notably, the widget-icon is a broken link, which may be a possible clue. I can drag the Ping360 widget onto the display, and it just shows up as a transparent box.
If I then click the settings button for Pint360, I get a screen that says “Iframe Source” http://blueos.local:6060undefined.
If i change this value to http://blueos.local:9092, then the widget window turns into a grey frowny file face. I have also tried these iframe source addresses, but never successfully connect to the sonar:
http://192.168.2.2:6060 – Tranparent background
http://192.168.2.2:9092 – frowny file
http://127.0.0.1:9092 – frowny file
http://127.0.0.1:6060 – frowny file
http://blueos.local:6060 ----> WORKS.
Ok, I answered my own question. Could someone explain what port 6060 is, and how it is different from 9092? Also, why does the 192.168.2.2:6060 (the vehicle’s ip address) not work, but blueos.local does? **
