Ping360 – Detection of microbubble plumes
Hello ,
One of our customers is currently assessing whether the Ping360 could be used to detect and qualitatively visualize underwater gas bubble plumes.
We understand that the Ping360 has previously been used to detect microbubble plumes in experimental studies. Could you please share any relevant scientific papers, application notes, test data or examples demonstrating this capability?
If available, we would also appreciate any recommendations regarding sonar orientation, operating range, scan sector and settings for this type of application.
Thank you in advance for your assistance.
Hi @Steph1, welcome to the forum :slight_smile:
I don’t believe we’ve been involved with this, but from a quick search online I found the following papers, which seem to be relevant:
Hope that helps!
Hi @Steph1 -
In general, there may be additional relevant papers here!
@Steph1
The Omniscan 3D is really good at producing 3D point clouds and 2D images of bubble plumes underwater. I scanned an object on the seafloor that was leaking air out slowly from a depth of ~60m, and was able to easily see the bubble trail as they were carried away with the current and up to the surface.
You can see the bubble trail created by a fast boat in the water for a few minutes after it passes.
