Hi Team,
Is their a way to output depth below transducer (from a ping 1D and Ping viewer) into a NEMA ASCII string?
Hi Team,
The Ping Sonar and Ping Viewer communicate using the Ping Protocol. You could write some code to convert measured distances into NMEA ASCII strings, but it’s not a built in option if that’s what you’re asking.
Out of interest, what’s this for? If you’re using our companion computer and don’t make a connection with Ping Viewer then companion will fall back to instead sending the Ping distances as range-finder measurements to QGroundControl, using mavlink
