No audio from mic on the Low-Light HD USB Camera when using QGC rev6?
(Shuhei) #1
Is there a way to re-enable audio feature from the ROV (the mic on the Low-Light HD USB Camera) when using QGC v3.2.4 rev6?
We can hear audio from the ROV when using QGC v3.2.4 rev4.
We love to use all of their five senses (acoustic sense!). Especially commercial divers!
(Patrick José Pereira) #2
Hi Shuhei,
It should work with the last version, can you check if the audio is not muted ?
Screenshot%20from%202018-06-14%2009-10-22
(Svein H.) #3
Hi @patrickelectric It seems like there is a issue here with QGC rev.6. This is the same fault as i have. i am back on rev4 until this problem has been fixed.
This led to another issue… There is no programmed buttons in rev.4 for the gripper so i hope we can solve this audio issue in rev.6 soon so we dont have to chose between sound or gripper…
(Shuhei) #4
Hi Patrick-san, the audio is not muted. Shuhei
(Svein H.) #5
Hi @hub Do you have any idea why we loose the audio from our sub when we install rev.6 ? As far as i know there is several people that thave the same experience now.
Cheers
@SHS
(Mark Langille) #6
Noticed same issue with Rev 6 with loss of audio but not investigated it yet
(Shuhei) #7
Hi @SHS, we have several PCs (all Win10) but no PC (QGC rev6) can hear. Need more investigation…
(Patrick José Pereira) #8
@SHS, @schoonerlabs, @hub, thank you for the report, an issue was already open and further investigation will be done.
