New Product! 4K Cam Low-Light ROV Camera
Hello, hello!
The time is finally here! The 4K Cam Low-Light ROV Camera is now available :tada:
The 4K Cam is an ROV piloting camera that prioritizes what actually matters underwater: low latency, excellent low-light performance, and accurate color. It delivers 4K or 1080p resolution, a motorized zoom-focus lens with up to 2x optical zoom, and a built-in tilt servo for camera angle adjustment. One-push and auto underwater white balance modes, with blue and green water presets, keep color accurate across varying conditions.
Designed for easy retrofit on the BlueROV2. Setup and camera control are handled through a BlueOS extension and Cockpit widget. An onboard Ethernet Switch is required for integration.
Below are some screenshot comparisons between the 4K Cam Low-Light ROV Camera and the Low-Light HD USB Camera.
Watch the product video and visit the product page for all the details.
We’d also love for you to join our 4K Cam Footage Club and share what you are capturing, wherever you are in the world! We can’t wait to see what you see :eyes:
Been waiting for this! Just put in an order! Can’t wait to test it :smiley:
Can the New 4K camera be fitted as a second camera and use stream2 with the normal piloting camera on stream 1?
Hi @ColinS1,
The new camera is designed to fit in the dome where the current camera lives, so there’s not an obvious space to put it if you want both cameras in the same vehicle (assuming you’ve got a single electronics enclosure and dome like on the BlueROV2).
Physical placement/mounting aside, both BlueOS and Cockpit are designed to work with multiple camera streams (so that aspect should be ok), but you’ll need to make sure you have sufficient bandwidth through your tether and decoding capacity on your topside computer, especially if you want to stream both cameras at full resolution.
I’m sure others will be interested in the setup you land on if you do decide to pursue this! :slight_smile:
Hi Eliot.
As you say it will not fit in the same pod with the standard camera. The plan would be to add a second pod. With connections to the main pod, to do this i would need Ethernet, Power and 3 servos, 9 or 10 way connector!
As you say bandwith may also be an issue, I have a standard 200m tether and Fathom x boards. The Tether has spare T/P have you any expereance using a second T/P and running two Fathom x cards?
Regards
Colin
Hi @ColinS1 -
Running two Fathom-X connections on the same tether will not work - they interfere and you don’t get any connection typically.
Are you saying you’d like to keep your existing USB camera, and also use the 4k Cam in a separate enclosure? I’m curious why you wouldn’t want to swap - the USB camera may be better suited to an external pod as it requires fewer signals?
The bitrate output of both the 4k Cam and the Explore HD camera is adjustable - this can make managing multiple streams over a connection easier to balance.
Hi Tony
I need to have the zoom and focus camera mounted on the roofrack. Most of the time this will be looking up and out of the water so it would be nice to have the zoom function. A USB HD camera would be ok for this, but then I found your 4K camera and thought it could be a possable solution.
Regards
Colin
Hi @ColinS1 -
An exploreHD is much better suited for this- the 4k cam is designed to be a primary pilot camera, and the housing you’d need to mount to the roof rack would be huge compared to the exploreHD! This would require a lot of ballast to get neutral, and generally the zoom is fairly minor, only 2x…
The 4k Cam can pivot to look straight up, and the optics are positioned nicely so seeing up through the surface works surprisingly well. I’d say upgrading the pilot camera to a 4k cam, and using a 2" enclosure to house the old USB camera for your second angle could be the most economical and logical approach! The cable you use to extend that connection will need to have the data wires tightly twisted together along it’s entire length…
Hi everyone,
We are designing a continuous drop-camera payload to be suspended from a winch down to 100 meters, streaming live video back to the surface. Sit will be used for AI, so we would like to push cost down for each deployment.
We are looking at both the 4K Cam and the Low-Light HD USB / exploreHD options, and would like advice on the cleanest shopping list and mechanical setup to get this running reliably.
Since this is a 5-100 m vertical drop, what is the most self-contained electronics chain inside the pod? For the 4K Cam, is it as simple as 4K Cam, Fathom-X, tether twisted pair, topside FXTI?
If we went with a USB cam instead, would it require a full onboard procesding (e.g., Raspberry Pi) inside the housing, or is there a leaner way? What pi could reliably run the reception and parts required to transmit to the surface.
Then, which enclosure size is recommended? Presumably a 4" series with a dome port if using the 4K Cam tilt mechanism, or a 2" series for a static camera?
Also, we need to mechanically attach the hanging load from the winch cable/rope directly to the housing chassis so there is zero strain on the WetLink penetrator or cable jacket.
What is the recommended bridle, clamp, or tow-point bracket for securing a 4" (or 2") tube to a lifting rope/wire?
Any suggestions for drop ballast/skid attachments to keep the camera oriented and stop rotation in cross-currents?
Would be really helpful if you can help with a specific list of parts as this is the first time we are building a underwater camera system :grimacing:
Best wishes
Torleif
Hi @tmlunde -
This guide is a good starting point - have you seen it already?
To use the 4k Cam standalone you’ll need components to send focus, zoom, and tilt settings - I link to a project that uses an ESP32 microcontroller with ethernet to provide a simple interface to generate and control the camera. A USB camera of any type will need a computer of some kind to translate the video stream into packets that can be sent over the network - it isn’t possible to extend USB signals the distances y ou’re talking about, over a cable! A single Pi 4 or Pi 5 running BlueOS can easily handle 4 exploreHD streams.
Any of these solutions does indeed the Fathom-X tether interface to communicate the long distance over the single twisted pair of Fathom tether - which could also be used to suspend the camera, as it has a 100lb working strength thanks to internal kevlar fibers.
3" enclosures can fit a Pi, but for the 4k Cam 4" would be required.
The tether can be strain-relieved in the same way it is on the ROV, with a tether thimble. Enclosure clamps can also provide means to bolt things onto the tube.
We typically keep it simple, with PVC frames of various arrangements and weights - dumbells or led “cannonballs.”
Here is an example from a recent trip - this was sent to 114 and 86 m, for a few hours!
And some students have built when piloting educational programs:
Are you planning to power the device with a battery in the enclosure, or by sending power down the length of the tether? Is it going to be a short-term deployment or something that is in place for days, weeks, months or years?
What are you using to winch the hardware up and down? It seems you’ll be streaming, and not needing to record video on board, or trigger a ballast release mechanism?
Hi @tmlunde,
I recently developed a standalone underwater drop camera system very similar to what you’re looking for, installed inside a compact Blue Robotics 3″ Series Watertight Enclosure with a 150 mm tube.
The system was designed for real-time monitoring and control of underwater ploughing equipment used for the maintenance, oxygenation, and cleaning of sandy seabed areas where clams and other mollusks are harvested.
VIDEO LINK: Complete system with PoE connection, low latency live video at 4K60fps / 60.000Kbps and touchscreen control.
DROP CAMERA SYSTEM — Technical Specifications:
Power Supply and Communications
- Single 50-meter tether carrying power and Ethernet data through PoE.
- Compatible with 12 V or 24 V DC input, depending on the vessel’s electrical system.
- Surface control box with two power outputs: one for the PoE system and another regulated output for the surface tablet.
- Estimated power consumption:
  • Camera and PoE system combined: approximately 11–12 W.
  • Tablet: maximum 36 W.
Surface Monitoring and Camera Control
- Rugged industrial tablet suitable for marine environments.
- Custom software optimized for tablets and devices with limited processing power, featuring an HTML-based touchscreen interface running directly in a web browser.
- Direct Ethernet control of camera functions, including zoom, focus, Anti-Fog, exposure, white balance, and other image settings.
- No Navigator, Raspberry Pi, ArduSub, or additional camera controllers required.
- Optional feature — External lighting control: Possibility to integrate remote switching of underwater lights directly through the camera’s web interface, using a relay connected to one of the camera’s digital outputs.
Underwater Housing and Camera
- Blue Robotics 3″ Series Watertight Enclosure, 150 mm tube.
- Sony IMX678 STARVIS 2 sensor, 1/1.8", with excellent low-light sensitivity.
- SS927 image processor, supporting 4K at 60 fps, with configurable bitrates up to 90,000 kbps (up to 160,000 kbps for local recording).
- Interchangeable lens system with two optical configurations:
  • Motorized lens: 3.6–10 mm (approximately 3× optical zoom), with autofocus and Fast Zoom using preset positions.
  • Fixed lenses: C-mount, CS-mount, and M12 options. The camera shown in this system uses a 3.2 mm, 12 MP CS-mount lens.
- Up to 5× digital zoom, applied directly to the transmitted and recorded video.
- H.264/H.265 encoding and simultaneous dual streaming, with independently configurable resolutions and bitrates.
- Internal microSD recording, allowing the main 4K60 stream to be recorded locally at maximum quality while simultaneously transmitting live video. Recording of the secondary stream is also possible if preferred.
VIDEO LINK: Underwater 4K60 image quality demonstration (Download to see in full quality)
The camera used in this system is the same one developed for my CustomROV 4K60fps project, but adapted to fit the 3-inch tube. You can find the full development details here: IP CAMERA 4K / 60FPS / Plug and play for BR2
Adaptation for a 100-Meter Deployment
The current system has been successfully tested with a 50-meter tether.
For a 100-meter deployment, the first option would be to verify whether the existing PoE configuration can operate reliably over the longer tether.
Alternatively, I have also developed a design incorporating Fathom-X inside the same 3″ Series Watertight Enclosure, confirming that all components fit correctly.
In this configuration, Fathom-X would handle Ethernet communications, while power would be supplied from the surface through separate conductors within the same tether.
Mechanical Adaptation
The external mounting bracket shown in the photographs at the beginning of the post, was originally designed for a specific underwater application.
However, it can easily be redesigned and manufactured with different geometries, including additional attachment points and ballast weights to maintain the camera’s balance and stability during deployment and operation.
The complete system can also be adapted to different power supplies, tether lengths, optical configurations, and surface monitoring requirements, depending on the final installation.
If you need any additional information or would like to discuss a configuration for your application, feel free to contact me directly at customrovs@gmail.com.
Regards,
Andrés
Thanks a lot for the breakdown and examples, this is super helpful!
We will be running continuous power from the surface over the tether for a long-term deployment lasting months or years, with weekly retrieval via winch for cleaning. Topside streaming only is sufficient, so no onboard recording or ballast release is needed.
I will plan around the 4 inch enclosure to fit the Pi, Fathom-X, and step-down converters. Could you share the link to that ESP32 Ethernet project for camera control? Really appreciate your help!
Hi Andres,
Thank you so much for sharing this! This looks like an ideal solution for what we are trying to achieve, especially running native IP over Ethernet without needing a Raspberry Pi in the loop.
Because we need continuous surface power and 100 meters of tether, your 3 inch design with Fathom-X looks like a perfect match. I will send an email over to discuss pricing, availability, and lead times.
Thanks again for jumping in with this!
Best wishes
Torleif
Hi @tmlunde -
You can find the project here - it was also linked in the building subsea cameras guide shared previously.
@Andres solution is very cool! In case you find the cost prohibitive, I’d mention that the 4k Cam has adjustable tilt, and being able to “look around” is quite handy for many applications. It also uses a dome, which introduces less distortion than a flat clear dome-port. Finally, the 4k Cam is mounted to RAILS within the 4" enclosure, making plenty of room for other off the shelf components.
We’ve run a few variants of internals, with the same 4"x200mm enclosure, enabling cameras in the fish-pen with a 140m tether, a DropCam that fits a 100WH battery inside the enclosure and operates at the end of a 300m tether, and a Tow-Fish powered over 8m tether, using subsea servos to drive control surfaces while being dragged behind a BlueBoat. Just the enclosure and camera come to about $1250, I would expect the tether and additional components keep your total around $2k for the system made from Blue Robotics components, potentially less!
Has anyone tried it in a 5inch dome and are there any distorsions?
