# Multiple Celsius Fast-Response Temperature Sensors with Multiplexor
**URL:** <https://discuss.bluerobotics.com/t/multiple-celsius-fast-response-temperature-sensors-with-multiplexor/7092>\
**Category:** Sensors\
**Created:** [March 24, 2020, 10:09pm UTC](https://discuss.bluerobotics.com/t/multiple-celsius-fast-response-temperature-sensors-with-multiplexor/7092 "2020-03-24T22:09:30Z")\
**Showing post:** 8
**Author:** ![CaptainPivo](https://avatars.discourse-cdn.com/v4/letter/c/a183cd/32.png) [@CaptainPivo](https://discuss.bluerobotics.com/u/CaptainPivo)\
**Post date:** [April 2, 2020, 7:05pm UTC](https://discuss.bluerobotics.com/t/multiple-celsius-fast-response-temperature-sensors-with-multiplexor/7092/8 "2020-04-02T19:05:34Z")
Hi, thanks for the reply.
I was able to get the sensors working but through a different method. I followed this guide and setup additional I2C buses:
> **[Raspberry PI Multiple I2C Devices](https://www.instructables.com/Raspberry-PI-Multiple-I2c-Devices/)**
> Raspberry PI Multiple I2C Devices: Frustrated because you can not use multiples of the same I2C devices in your project. No need to use slow multiplexers. The latest raspbian kernel support the creation of multiple I2C busses using GPIO pins. This...
I’ve since run into a new issue, however it has to do with the Adafruit LSM6DS33 IMU. I have the IMU connected to default bus 1 and the sensors connected to the created buses 3 and 4 (on the GPIO pins). I can detect the IMU but it will no longer initialize.
If you have any idea to a solution for this that would be great! Otherwise I understand if you don’t and will reach out to adafruit as well.
_[View the full topic](https://discuss.bluerobotics.com/t/multiple-celsius-fast-response-temperature-sensors-with-multiplexor/7092)._
