Hi, thanks for the reply.
I was able to get the sensors working but through a different method. I followed this guide and setup additional I2C buses:
I’ve since run into a new issue, however it has to do with the Adafruit LSM6DS33 IMU. I have the IMU connected to default bus 1 and the sensors connected to the created buses 3 and 4 (on the GPIO pins). I can detect the IMU but it will no longer initialize.
If you have any idea to a solution for this that would be great! Otherwise I understand if you don’t and will reach out to adafruit as well.
