I try to download the latest stable build image of BlueOS for raspebrry pi5. Latest is 1.4.3 but the hyperlinks on the webpage are not working. Do I miss something? I want to flash it with Balena etcher. here
Hi @Charles -
We don’t have images out of the build process for 1.4.3 yet. When they’re ready, they’ll show up here. Hopefully that will before the end of the week, right @patrickelectric ?
Hi @tony-white . Is there a build somewhere for a pi5 or this will be the first one?
I don’t mind using an older build for testing if it work with Pi5.
Hi @Charles -
You could download the Pi 5 image for this image - I would strongly recommend you update via the online interface on first connection to the latest 1.5 beta release, or 1.4.3 stable - either should be available to install once you’re in the BlueOS Version menu!
If you’re using an older Navigator, it may have some issues with the magnetometer, it is in too close proximity to the heatsink cooling fan. The pi5 does much better with a fan!
