# Mavlink code in python won't work properly when QGC is not running
**URL:** <https://discuss.bluerobotics.com/t/mavlink-code-in-python-wont-work-properly-when-qgc-is-not-running/13239>\
**Category:** Blue Robotics Software\
**Tags:** pymavlink\
**Created:** [November 18, 2022, 9:48pm UTC](https://discuss.bluerobotics.com/t/mavlink-code-in-python-wont-work-properly-when-qgc-is-not-running/13239 "2022-11-18T21:48:49Z")\
**Showing post:** 4
**Post date:** [November 20, 2022, 9:20pm UTC](https://discuss.bluerobotics.com/t/mavlink-code-in-python-wont-work-properly-when-qgc-is-not-running/13239/4 "2022-11-20T21:20:50Z")
> [@legohead259](#):
> Are there currently any best practices laid out for trying to control a BlueROV through Pymavlink?
The current pymavlink documentation and example sections I’m aware of are
- [The official documentation](https://mavlink.io/en/mavgen_python/)
  - Currently assumes you’re already familiar with MAVLink, and just want to use Python to interface with it
- [The Blue Robotics examples](https://www.ardusub.com/developers/pymavlink.html)
  - Useful snippets that don’t fully cover the nuances of creating full programs
- [The Pymavlink source repository](https://github.com/ArduPilot/pymavlink)
  - Includes [the ArduPilot examples](https://github.com/ArduPilot/pymavlink/tree/master/examples)
    - Snippets that aren’t focused on vehicle control, but do make use of some interesting features
  - [mavutil.py](https://github.com/ArduPilot/pymavlink/blob/master/mavutil.py) can also be worth a read, for understanding available utility functions
- The [abstractions used in the ArduPilot test suite](https://github.com/ArduPilot/ardupilot/blob/master/Tools/autotest/common.py#L1471)
I wouldn’t really class any of those as examples of best practices at the moment, which is part of why I’m planning to revise our examples documentation when I transfer it over - good practice full program examples seem like they would be beneficial. It is somewhat unhelpful that ArduPilot’s examples maintain backwards compatibility with quite old versions of Python, which means newer Python features are only covered in external examples.
> [@legohead259](#):
> We thought about a janky work around using a separate thread in the main application to send a heartbeat at 1Hz, but that seems unwieldy.
I’ve got [a reasonably extensive example](https://gist.github.com/ES-Alexander/ee1dd479dd728b7cef1bf936f9114e71) which takes that approach, but there are some notes at the bottom about why that’s not necessarily recommended, and an alternative (synchronous) approach.
@patrickelectric has also made [an example using asyncio](https://gist.github.com/patrickelectric/d6264fe309d01b44d5540d75cc45cb83). I expect asyncio is likely the best approach for the main thread of more complex MAVLink-based programs going forwards.
_[View the full topic](https://discuss.bluerobotics.com/t/mavlink-code-in-python-wont-work-properly-when-qgc-is-not-running/13239)._
