Looked at both logs. The vehicle is arming with PreArm: Throttle not centered/close to trim. For a sub that means MANUAL_CONTROL.z is not around 500 with the sticks centered. 0 is full down, not neutral.
Your joystick mapping has Z on axis 2 at -1000 → 1000. The ROV default has Z on axis 3 at 1000 → 0. So at rest Cockpit is sending z=0, which is full motor.
Safari working is because it still had its own local mapping. Chrome was wiped, so it loaded the vehicle copy, which was wrong.
In the joystick page, table view, put Z on the axis that actually moves when you push the stick up/down, and set the range to 1000 → 0. Or use the “import default mapping for this vehicle” button.
