When i upgraded to BlueOS 1.4.6 , ArduSub 4.7.1 and Cockpit 1.18.4 STABLE
my Newton Subsea Gripper is not working anymore.
I thought there was something wrong with output 9 to gripper,so I use servo camera input instead of.
I have try to connect the Newton Subsea Gripper to the servo camera input.
But it’s not working,the light on the motor’s circuit board comes on.
but I cannot control the motor with the buttons.
I have tested just the motor without the ESC,the Gripper motor works.
So there is something wrong with the ESC?
The Bar30 high-pressure comes up as Unknown in BlueOS 1.4.6 (shall be MS5837-30BA)
Hi @an-ron -
See this post for information on the change in newer Ardusub versions to Actuator outputs! Chances are your gripper is just fine - your test with it connected to the camera tilt channel would only produce motion when you got to the max/min PWM value for tilt.
The “Unknown” listing for the Bar30 is a known driver issue with ArduSub 4.7 - it should still work fine, and the ID listing will be fixed in 4.7.2.
