I am a new BlueBoat user and recently completed the initial setup using QGroundControl version 4.2.8. The setup process went smoothly following the documentation, and I was also able to successfully configure all functions on my Xbox controller with one exception — I cannot locate an option to assign a Forward/Reverse (surge direction) control in the joystick button assignment menu.
I do not see a Forward/Reverse function in the dropdown list of assignable commands. Has anyone configured an Xbox controller for BlueBoat in QGC and found a solution for setting up forward and reverse control?
Any guidance or recommended configuration steps would be greatly appreciated. Thank you in advance for your help.
