We have just come from the field with some images. We used the Oculus M3000D for the first time to inspect pier piles. The river conditions were awful. Current of about 2 kn, water level very high and above the pile heads, and a lot of a floating layer of plants.
Here is a typical image of our survey. How would you interpret this?
At first glance I thought there were mussels attached to the pile. However, I think this is not the case.
It is a built in place concrete pile with a steel casing.
Hi @jeabramian -
Blue Robotics does not sell the Oculus, and has not tested with it… however, interpreting that image is similar to the Sonoptix Echo. To me, it shows the ground from 2-4m away with a lump tecture. There may be a rope or line just under 2m away?
What angle is the sonar mounted at? Did you try pitching up or down when collecting data?
What is your goal for the sonar images? An imaging sonar is not typically used to make a map, but navigate or visualize objects in the murk… what aspect of the pier pile would be inspected?
The sonar is looking down at 80°, more or less. The depth was about 12.5 m and the sonar is at 5.6 m. Therefore, the bottom is somewhat farther down. The line you see at about 2 m from the sonar (actually at about 8.6 m from the surface) may be a rope or, more likely, a root from one of these floating plants.
The question is that I see a very rough surface on the pile. I thought river mussels - mussels from China, we use to say here - had attacked the steel surface of the pile. But in some pictures from 2 years back, when the river was lower, I could see the steel casing falling apart and the concrete exposed here and there. Here is a picture of that time. Could the sonar be picking up this surface and amplifying the roughness? Why does the sonar image look like it is showing something growing?
Hi @jeabramian -
Can you share more about how the sonar is oriented vs. that metal piling? The imaging sonars are not typically pointed down at the bottom directly, but parallel to it, maybe angles 20-30 degrees from horizontal at most?
If the sonar was close to the post, looking down at the bottom, then the texture in the center of your image could be the pole itself, with biofouling growing on it? No reflection was returned on either side of the pole (expected?) if that is the correct way to interpret this situation…
I would not expect the smooth rusted metal surface to look that bumpy on sonar! Is it possible something is growing on it now? Fouling can clear pretty quickly once exposed to air…
The sonar was actually looking down at 80° from the horizontal to give long shadows. We can try, as you say, tilting it less. In that case, I believe it will not look as rough, as the shadows would be shorter. It was expected that either side of the pile would be dark, as we are working with high frequency and a range of 4-5 m, and there was nothing close enough to show up. The big question is whether we see biofouling or steel degradation. Two years ago, looking at the upper parts of the piles that stood above the water surface, I was able to see that the steel casing, which should be around 1/2" thick, was disappearing here and there (after about 50 years), showing the concrete behind. And that concrete was also rough because the current was eroding the fine particles, and the gravel was protruding.
