Holybro Mosaic H RTK GPS
Hi all,
I had a working solution with Holybro Mosaic H RTK GPS on the BlueBoat but unfortunately had to reset everything and now I cant get the GPS to connect with the Navigator! When I connect the GPS module to the computer I get a position and have set it up according to the manufacturers instructions.
In the BlueOS GPS status bar it says “GPS connected, but no position fix”.
To the best of my knowledge everything is setup as it should be:
Serial Port configuration udpin:0.0.0.0:27000
Parameters as per this file:
Surface Boat-4.7.2-STABLE-20261101-100716.params (18.4 KB)
What did I miss?
/Patrik
Hi @Patrik,
Not sure it will be the cause of your issue, but from a quick look at your parameters it seems you’ve got the GPS1_MB_OFS_X parameter set to an offset of -93m, which could mean you’ve set some parameters incorrectly, or loaded some parameters from a previous version that don’t map exactly to those in the firmware you’re running.
If you have a set of functional parameters for a specific firmware version then it may be worth flashing on that firmware version, loading those parameters, then updating the firmware so it can correct the parameters for you automatically.
Hi @EliotBR ,
Thank you for your quick reply. Thank you for noticing the offset, it is supposed to be -0.93m :slight_smile:
I corrected that offset and restarted the boat, unfortunately the issue persists.
Edit: I have some issues loading the old parameters, it seems like the Navigator can´t write them all. Specifically the ones relating to the nav-light (already implemented the .lua file from one of @tony-white posts) and the MAV3 settings, could that be the issue?
Hi @Patrik -
What did you “reset” when things broke? What motivated you to do this?
Are you using a weather station with wind sensing? I notice your parameters have that set for a Serial_Protocol…
How is the RTK GPS connected to the system? The udpin setup is used for external GPS that communicate via the network, but I’d guess your GPS is connected via USB or Navigator serial port? You likely need to make sure Serial1 (currently set to Serial_Protocol that matches your GPS type) is mapped to the correct physical port on the Autopilot Firmware page, in pirate mode.
Otherwise, if the system is inside and configured correctly, you may still encounter that error message - as it is tough to get a position fix inside!
Hi @tony-white ,
Thank you for your reply.
I was struggling to control the boat via both wifi and the 4G cellular modem. There was massive lag and basically impossible to do anything useful. There was a packet loss of 99% in QGroundcontrol. I decided to redo it all, step by step and see if I had changed something by accident.
I reinstalled BlueOS (etching…) and factory reset the navigator. Funny enough, when I reinstalled everything and kept an eye on the packet loss it was all good until SonarView was reinstalled. Then the packet loss spiked, but went back to normal when I removed it.
The RTK GPS is connected to Navigator serial1 and in the Autopilot Firmware page, serial 1 has udpin:0.0.0.0:27000, is that not correct?
Yes it is indeed difficult to get a position with the boat inside, so I keep it outside to make sure that the RTK GPS gets a position (also verified via USB to the GPS).
Hi @Patrik -
Given the problem seems connected to SonarView, what Cerulean product are you using with your system?
The udpin setting as you have it is NOT correct - from the FAQ:
Your unit is not a network connected RTK GPS, but a serial connection!
If you move the connection to serial3 or 4, and set the appropriate protocol parameter, things should work!
Serial 1 is often avoided, as this same port is also used for setups that have an SBUS receiver connected to the Navigator.
