Hi. I’m trying to install gstreamer and following the guide from Deepwater Exploration: PC Setup Guide - DeepWater Exploration docs
I have done everything in the correct order and i am in the following step: To test the gstreamer setup, open CMD and run the following:
gst-launch-1.0 --version
When i type in that command in CMD i just get the following answer in CMD: ‘gst-launch-1.0’ is not recognized as an internal or external command,
operable program or batch file.
If you’ve installed it and added it to the Path variable as described then it should be findable, although you may need to start a new instance of CMD for it to work.
I’m not really sure beyond that - you might want to try contacting DWE (or asking on their forums), since it’s their instructions you’re trying to follow.
Side note @DeepWaterExploration: the contact us page in your docs currently points to an old/broken forums link, which you likely want to fix (or just redirect people to your main website’s contact page)
